"plastic bushings" in 4L60E ?
Old 10-11-2004, 07:34 PM
Bad30th's Avatar
Default "plastic bushings" in 4L60E ?
Where are the "plastic bushings" in the 4L60E - one of the rebuild shops I spoke to said they would replace them as part of a heavy duty build-up.
Is it worth replacing them ? I don't think I've ever heard of anyone breaking them before...
Anyone know about them ?
Bad30th
Old 10-11-2004, 07:49 PM
TeamTripp's Avatar
There are a few plastic thrust washers. The two most common to replace with Torrington bearings are between the reaction carrier shaft and the sunshell, and between the sunshell and the lo-roller inner race. The whole point was to try and take heat away from the spline of the sunshell, but with a beefy sunshell, its not really needed.
Old 10-11-2004, 07:56 PM
Bad30th's Avatar
Thanks !
Bad30th
Old 10-12-2004, 06:07 PM
Rock-On's Avatar
They maybe talking about the teflon coated bushing in the pump, thats one I'd get rid of for sure, also alot of talk about the plastic accumlator pistons; again something we'd dump on all rebuilds. I'm not aware of any plastic bushings, if your guys are talking about plastic bushings I'd move with caution.....hope this helps..Dave
