Probably going 383
Probably going 383
You guys running 383's, what sort of head/cam combo's are you running? Specs? I would like to make safely over 450RWHP on my A4 and I dont think it will be too diff with the right setup. If anyone wants to chime in on what all is done to the motor it would be greatly appreciated! ...as far as crank, rods, pistons, what heads, what cam, springs (single or dual), all the way down to what head gaskets you are running. Just want to see what people are using a learn from it so I can make the right choices while selecting which parts to put in the motor..
I am going forged bc I will be spraying probably 200 shot max. F2 kit maybe?
Eagle or Lunati?
Thanks
Eagle or Lunati?
Thanks
https://ls1tech.com/forums/dynamometer-results-comparisons/219762-new-383-tsp-magic-stick-numbers.html
friend of mine's car...put that down on a nitrous tune also. I should be dynoing mine very soon as well
Callies 383 forged crank and rods
Diamond pistons 3.905"
Cometic .043" gasket
Rapid Stage 2 LS1 head 66cc
Rapid cam 242/250 .595/595 109
Comp R lifters
Pro Magnum 1.75 rockers
LSX 90mm
ARP hardware
Kooks 1 7/8 LTs ORY LM
March pulley
Heavy steel driveshaft, Billet steel flywheel, Moser 4:11, 17" stock wheels/tires
~10.5:1 compression 92 octane, air filter in, full belts
480rwhp/440tq
do a search a you can find out everything else including dyno graph.
Im sure 11:1 with LS6 heads would have put me way over 500rwhp...but it was not in the budget.
Comp R lifters
LSX 90mm
ARP hardware
March pulley
480rwhp/440tq
