Lifter Adjustment
Old 10-14-2004, 12:14 AM
Silver02's Avatar
Default Lifter Adjustment
I have lots of noise under the right side valve cover and the car has very little power. Is it possible that if the lifters are not adjusted properly?
Old 10-14-2004, 01:17 AM
luv2spd's Avatar
You don't adjust the lifters. You adjust the amount of preload placed on the lifters. You might have a collapsed lifter and if that's the case, the heads have to be pulled and the lifters replaced. What are the specs of your cam and valvetrain setup? Stock lifters, rockers?
Old 10-14-2004, 11:35 PM
God of Thunder's Avatar
lots of noise like what? rattling and ticking? maybe its a busted rocker arm or rocker arm bolt. just pull the valve cover and see if you can find anything
