75 lb injector tuning ?
Old 10-14-2004, 08:11 AM
Earl H's Avatar
Default 75 lb injector tuning ?
I am going to be installing my 75lb @ 3 bar(hi-z) injectors this weekend and need to adjust my tune accordingly. I am looking for guidance in adjusting my injector flow rate tables for the new injectors. I've found resources (worksheets) that provide calcs, but the values seem way too high when compared with the stock calibrations. I'm looking for input from guys that have tuned their cars with the new RC Engineering 75lb injectors…what are the values that you have for flow from 20 - 100 kpa (in 5 kpa increments)? Thanks in advance for your help. By the way I am still running the stock (i.e. fuel pressure regulator in the rear) setup.
