knock sensor code questions.
hope this is the apropriate section. the code is not excessive knock it says low voltage or short from knock sensor. any idea what causes this? i'm guessing maybe a bad sensor or wire. was also told it is a pain in the *** to change the sensor cuz it is under the intake.....any wisdom on this? I thought they were in the head.
You answered your own question I had the same problem, low voltage to the front knock sensor. I replaced them both with a new ones, wrapped some teflon tape around the threads and sealed them with silicone for good measure(there is a tsb on this). Inspect the wire harness for any nicks while you are at it. It wasn't hard to do, remove the intake and the sensors are right there, about an hour or two job at the most.
so you do have to pull the intake off. hell if i do that might as well find a ls6 to throw on there then right?
BTW any idea where I can find info on the TSB for this?
Yeah now would be a good time to change over to LS6 or LSX. I did a quick search and found these threads on the tsb...
https://ls1tech.com/forums/showthrea...ock+sensor+tsb
thanks for the info. i did a search on knock sensor but I didn't go far enough down the list i guess....went back to the begining f this year then posted my question.
BTW what is a LSX intake?? i've only had my LS1 for a month can ya tell!!!
