Confused after reading VE sticky
Old 10-16-2004, 05:41 PM
itchygomey98's Avatar
Default Confused after reading VE sticky
Nogo'sve% = MAF.gp/s*(IAC+273)/((346*RPM)*MAP)*212544
Is this for Ls1 edit, or HP tuners?
I am using edit, so if it is for HP, what do I need to do so I can use it?
Old 10-16-2004, 06:22 PM
HumpinSS's Avatar
if you are using edt them the formula is
VEpcm = {SAE.MAF.gps}*({SAE.IAT.C}+273.15)/(346*{SAE.RPM}*{SAE.MAP.kPa})*6376320
Old 10-16-2004, 06:30 PM
So I should be able to log MAF GPS, IAT, RPM, and MAP with autotap, and then caculate for that cell right?
Old 10-16-2004, 10:21 PM
HumpinSS's Avatar
yup that will work
