Annoying Rear End Noises and how to fiX?
My car sounds great...0-40 but it seems like the second i go over 40 and am on the highway...i get this whining noise when my foot is on the gas..seriously...now it even does it when my foots off the gas sometimes...it remind me of a nascar..noise..and its coming from my hatch it seems like...i know people have had this problem.....
Can you tell me what i need to fix it...how much it will cost...where i can get it..and if i can do it myself..Thanks Alot..
Also my mechanic already bleed the rear end..and refilled it..it wasn't that..plz ne help would be appreciated..
Thanks for any replies
My rear end is noisy as well 2000a4 w/2.73 and I really this mine is back lash. Changed the rear end fluid 3x in 45,000 miles and have not seen ANY metal shavings in all this time, so I just accepted it for now.
If your gears are stock, and have never been changed then like 2muchrice said, your rear is probably about to kick the bucket. On the other hand, if the gears have been upgraded from 2.73's to your 3.23's then the spacers might be the cause for the problem. I know that my ricmond 3.73's whine, and that is because when I put them in I eyeballed my spacing from the stock gears. Not to mention some aftermaket brands whine even if spaced correctly. If its completely stock I would suggest an entire new posi unit in your rear end. Prices vary from brand to brand, but before you buy anything have your axles checked too. You might just need to rebuild the entire thing, or vote to go get a 9 inch or 12 bolt if you have the money.
Originally Posted by msbz_ls1
how much?....woul dneed to be saved up ..and waht rear end woul du go wit?
Yeah, I said that because his sig says "bone stock" so I assumed that he did not replace the gears.
It really depends on how much power you plan on making. There is alot of options out there. You can either get a 12 bolt or a 9" but there are alot of options you can go with. Try doing a search in the gear section youll find alot of info there on which one will be best for your setup.
