question about the valvetrain
liqour enthusiest
would a bad lifter or bent pushrod cause my car to run like crap when accelerating? my car runs fine at idle but when i accelerate around 2k the car starts bogging and i have this tick comming from my passenger side of the car. i checked the plugs and they are tight but the coil packs(the thing that bolts to the valve cover) are just hanging there,, im going to mount it back up tommorow and see whats going on, but i was hoping you guys could give me some info before i start ripping the block apart.
liqour enthusiest
Originally Posted by Z28Venom
It could possibly be a bent pushrod... Do you get an SES light when the studdering happens, or at any other time?
liqour enthusiest
Originally Posted by 88monte
nope, the only code im throwin is a knock sensor code and thats cus the rear bank is bad. but other than that. no codes
my car idling
Usually, the pushrods won't make your car "bog". They tend to take power down across the board (most noticible in the higher RPM range 4500 up-trust me, 1st hand experience) and as far as I know won't throw a code. To me, it sounds like that hanging coil pack might be your issue. If it's not that I would look towards something dealing with your fuel or breathing.
I would suggest getting a dyno that has an A/F ratio graph....a good tech could probably give you a good idea what's going on from that.
Good luck.
Good luck.
liqour enthusiest
Good luck.
Good luck.
liqour enthusiest
What are all of your modifications?
a nice size cam and stock intake.
its a 382 with ls6 heads that have been ported and polished.
Really, to hard to tell without seeing/hearing or a lot more information.
liqour enthusiest
....you could also be floating valves.
