Will FTRA inlet fit SLP CAI?
Old 10-22-2004, 11:01 AM
Larry's Avatar
Default Will FTRA inlet fit SLP CAI?
Will the Fast Toys lower inlet collector fit the SLP cold air upper ram air?
Old 10-22-2004, 11:55 AM
WILWAXU's Avatar
Larry, I believe Fast Toys sells a kit that bolts to the SLP kit.
Drop them an email: sales@fasttoys.net
Old 10-22-2004, 12:43 PM
Larry's Avatar
I have the Fast Toys lower inlet and need the upper portion. I emailed them and they won't sell the upper separately. I have an opportunity to buy an SLP CAI but not sure if it will fit. If the Fast Toys kit you are referring to is the same as I have then it should fit unless they make a version to adapt the SLP.
Old 10-24-2004, 07:15 PM
WILWAXU's Avatar
I know that older FTRA's used a scoop that was dimensionally the same as the SLP. Not sure about newer stuff.
Old 10-24-2004, 08:02 PM
Larry's Avatar
I think they will probably marry together but now I have another problem. I don't have AC nor a condenser and from all the pics I've seen they mount on top of the condenser. Maybe I should give up my ram air notions, sell my FTRA scoop and go with what I already have. Thanks for your help!
Old 10-27-2004, 08:14 AM
WILWAXU's Avatar
The flange screws to the core support. No condenser needed. In fact it's alot easier to install without the condenser.
