Single wire water temperature sensor?
Old 10-24-2004, 06:49 AM
rotarnomore's Avatar
Default Single wire water temperature sensor?
Does anybody make a single wire water temperature sensor that will directly fit the ls1 heads?
Thanks,
Chris
Old 10-24-2004, 11:59 AM
BADFNZ-383's Avatar
i got mine from cyberdyne when i ordered my water temp gauge from them.
Old 10-24-2004, 10:34 PM
John_D.'s Avatar
You could get a 3 wire sensor made for a '98, and pull off of the 3rd wire. (if you also got a connector for it.) Not sure what the signal range is exactly, but it's the same one that directly drives the gauge on a '98 f-body. The other 2 wires go to the pcm, same as the 99+.
Old 10-24-2004, 10:55 PM
Ferocity02's Avatar
Or you can get one from Autometer, I'm not sure if it comes with the right adapter, probably not. But it is one wire, and would have to go in the passenger side head. Easiest way to get to it is to remove the header and put it in from under the car.
Old 10-25-2004, 06:34 PM
Thanks for all the replies. i have a 98 sensor and i didn't know what the 3 wires were for. I can just use a potentiometer to adjust for the range that i need.
Chris
Quick Reply: Single wire water temperature sensor?
