People who have removed their PCV system...
I've about had it with the PCV system and plan to remove it. I have everything I need, but just have one question. On the pass side valve cover there is a line from the front of the VC, which leads to a metal 90 bend out from the throttle body. I believe that this is a freah air line, as the source is on the upstream side of the TB Blade. When removing the PCV system and going with breathers, does this line get removed and capped at both ends(TB & Valve Cover), or do I leave it intact?
Thanks,
Mike
Thanks,
Mike
