Dragaholic
10-29-2004, 12:48 PM
Just wanted to see what all sponsors cam doctor all their cams. Would make it easier on me so that I didnt have to degree a cam. Thanks.
1fastWS6
10-29-2004, 03:34 PM
Doctoring it doesn't relieve you from needing to degree it. How do you know you're timing chain and everything else is 100% accurate? Granted, it helps knowing the cam specs are accurate, but there can still be other variables. Obviously it's not critical on a small cam, but on larger cams it needs to be checked in the motor 100%.
Angie
10-31-2004, 09:05 PM
We check every one of our cams on our Cam Pro Plus before it is shipped out to the customer. This way, you know the exact specs of the cam that you are getting (not just advertised specs) and it is also ensuring that all Thunder cams are ground within our specs.
Angie
