firing order
Old 11-10-2004, 11:58 PM
deznuttzz28's Avatar
Default firing order
this might be a dumb question, does 1998-2002 LS1's
has firing order??? i heard from others that they don't...
thnks..
Old 11-11-2004, 01:05 AM
SidewaysTA's Avatar
Old 11-11-2004, 08:21 AM
Quick 99's Avatar
Originally Posted by SidewaysTA
1-8-7-2-6-5-4-3
yup!
Old 11-11-2004, 10:22 AM
StEvO_kInEvO's Avatar
didnt know that... what ever happened to the old 1-8-4-3-6-5-7-2???
Old 11-11-2004, 11:32 AM
SidewaysTA's Avatar
I don't know, maybe GM had a good reason to change it, or maybe they just thought 1-8-4-3-6-5-7-2 was played out.
Mike
Old 11-11-2004, 11:51 AM
Mike454SS's Avatar
When switching from 1-8-4-3-6-5-7-2 to 1-8-7-2-6-5-4-3, I think GM was trying to make a smoother running engine. On the old firing order, 5 and 7 are not only right next to each other in order, but also in their physical location in the block and in where they pull intake air from in the plenum.
A lot of pre gen 3 small block guys have tried messing with 4-7 swap cam's, and they have usually found decent results, but at the same time, their firing order is now 1-8-7-3-6-5-4-2, so they wind up with 2 firing next to 4...similar problem as 5-7 in the original firing order. By swapping 4-7 AND 3-2, you get rid of the 5-7 problem and the 4-2 problem. You now have a 1-3 problem though, because the firing order could be looked at as 1-8-7-2-6-5-4-3-1-8-7-2-6-5-4-3...on and on...but 1 and 3 are closer to the throttle body than 5 and 7 are, so maybe GM saw fit to move the problem area closer to the throttle body to help wave propagation through the intake plenum...2 and 4 are not quite as close to the TB as 1 and 3 are...I dunno.
Old 11-11-2004, 11:53 AM
12secSS's Avatar
Every engine has a firing order, it won't turn without it. The reason for the firing order change was to smooth out the idle. This firing order is what is on the Fords and Chryslers (IIRC). The old firing order was a bit of an odd firing order. This also affects the exhaust sound of the engine, the reason why the LT1 and LS1 do not sound the same.
Old 11-11-2004, 12:52 PM
SidewaysTA's Avatar
Yeah, i figured it had to do with smoothing out the engine.
Mike
Old 11-11-2004, 01:21 PM
66ImpalaLT1's Avatar
This firing order is not the same as Ford. Ford numbers their cylinders sequentially per bank, not even/odd.
Old 11-11-2004, 01:26 PM
777's Avatar
i suppose that is why they sound so much different...is that why they have the hollow sound..or would that be their exhaust combo?
Old 11-11-2004, 02:08 PM
ILLEGAL's Avatar
so the LT1s order is 1-8-4-3-6-5-7-2??
Old 11-11-2004, 06:26 PM
Redlinez's Avatar
They even # the injectors too. Pretty cool.
Old 11-11-2004, 08:43 PM
WS6FirebirdTA00's Avatar
firing order is on the intake manifold, seen that replacing it, thought that was kinda cool lol
Old 11-12-2004, 08:34 AM
cool, this is what i need to know..
thanks alot guys..
Quick Reply: firing order
