Can you use a buffer to apply Zaino?
To wipe off, yes, but I would apply by hand. The trick with Zaino is thin coats. If you apply with a machine, you will use too much and it won't come out as well as if you apply by hand. When I use Zaino, I apply with a cotton applicator then buff off with a microfiber towel folded and stacked between the car and my orbital buffer. I follow up with a clean towel to wipe off anything left, then use the Z-6 spray stuff. Works great.
-Mike
-Mike
I've used Zaino for almost 2 years now, and have always used a towel to wipe off Zaino. I wasnt sure if there were any benefits to using a buffer to wipe it off.
None, really. If it's thin enough and totally dry, it comes off easily with a towel. I usually put a little too much on the side panels, so I break out the buffer for those.
-Mike
-Mike
