LS6 Maf? will it work?
I was planning on either polishing out my MAF sensor or changing it.. Is it possible to use an LS6 Delphi Stock MAF sensor for a corvette? I will have an LS6 intake.. and i'm planning on getting a Shaner TB(S3 or the new Billet).. Is it better to leave my MAF alone? Anyone tried the LS6 MAF? Let me know what you think or if it even works! Thanks!
I got mine from Speed Inc. It's callibrated to work with the Camaro/TA. I changed mine at the same time I installed the ported tb, ported ls6 intake, pulley and partial edit... I noticed a nice gain but not sure if you would notice a gain with just the MAF.. But from what I am told this is the easiest meter to tune with vs the other meters. And for $150, every little bit helps..
everyone i know with a 2000 has problems with a maf. dont know if its something in their computers or not but i sold mine to my friend wiht a 98 and just got ported ends with the money i got from that. unless you have bigger cubes and a matching larger intake i wouldnt get a larger MAF. 75mm MAF and 78mm Tb they are close. no real need to get an 85 mm MAF with a 78 mm TB. now if u have a 90 mm intake/TB combo i would see it being worth it more. but thats just what i think. maybe cause i had bad luck with mine. just dont go to slp they are no help
