tach signal
Old 11-17-2004, 12:31 PM
rons 00z's Avatar
Default tach signal
does anyone know what the signal that comes off the PCM to the tach is?
Old 11-17-2004, 12:36 PM
horist's Avatar
if your car's an 00 as your name would imply... white wire, #10 pin
I forget which connector it's on... but only 1 of them has pin 10 used ...
Old 11-17-2004, 12:47 PM
HumpinSS's Avatar
Blue block IIRC
Old 11-17-2004, 02:30 PM
rons 00z's Avatar
ohh i guess i asked wrong what type of signal? is it like a 1 pulse per second does the frequency change the higher the rpms go up or does the voltage change. i had a great idea pop through my head so i need to build a circut too see if my idea actually works or if it was fart that just leaked up in the void i call a head
Old 11-18-2004, 10:40 AM
JS
JS's Avatar
Thats the one---------->#10 white....
