Anyone with an ASP pulley???????
Old 11-18-2004, 10:49 PM
SpdfreakLS1's Avatar
Default Anyone with an ASP pulley???????
What is the bolt size i need to remove the pulley. I think they are a fine thread metric. Anyone know? It should say on the instrustions....i dont have them. Thanks!
Old 11-19-2004, 01:17 AM
Z28Venom's Avatar
24mm socket...
www.ls1howto.com
Old 11-19-2004, 02:57 AM
HavATampa's Avatar
I think he means the 3 smaller threaded holes, not the crank bolt size. Not sure what size they are, it's not a standard size that comes with pullers. A regular 3-arm puller works just fine though.
Old 11-19-2004, 05:37 PM
WILWAXU's Avatar
over the years I've seen a couple different setups on those holes...
Old 11-20-2004, 01:20 PM
Addicted's Avatar
The first time I had to yank my ASP I couldn't figure out the size of bolts needs I ended up just calling and asking and they went in back and looked at the tap.. I then bought a set of bolts that work on my ASP, if I wasn't 330 miles away from them I'd go try to figure out what they are but if I were you I'd just call ASP.
Old 11-21-2004, 04:34 PM
01_SuperSlow's Avatar
When I had to remove mine, I did a search and found what I was looking for in threads similar to these. Search is your friend
https://ls1tech.com/forums/showthrea...ing+asp+pulley
