AFR 205 question
Old 11-20-2004, 06:43 PM
jub jub's Avatar
Default AFR 205 question
How much would you need to shave off the AFR 205 heads to raise the compression ratio to 11:1?
Sorry if this is a repost but I wasn't having to much luck with the search.
Old 11-20-2004, 06:44 PM
pdd
pdd's Avatar
.024
Old 11-20-2004, 06:54 PM
jub jub's Avatar
Thanks!
Old 11-20-2004, 09:44 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Default Just to further clarify...
With the use of .040 gaskets .024 is correct (62 cc's)
Stock head gaskets are thicker and will yield slightly less than 11 to 1.
Tony M.
Old 11-20-2004, 10:28 PM
Viper's Avatar
So 60 cc's would be 11.3 with the same gasket? I can get 94 octane in Cleveland; what is the safest compression ratio I can go N/A on 94?
