What cam with TEA Stage 1.5 5.3 heads???
I'm picking up a set of TEA 1.5 5.3 heads, I was wondering what cam will work the best with these heads. I've seen that people are recommending that a cam with more duration on the intake will work the best, but I can't seem to find one that I like. I want a decent size cam that's bigger then the cam I have now with a 114 LSA, and was looking for about 420+ at the rear wheels. I have a TR224/224 .563/.563 112LSA with a Moser 12 bolt 4.11's, someone point me in the right direction!
Thanks
Thanks
I figured since I will have the engine apart I was going to change the cam out to benefit the heads, so should I keep the cam? I emailed TEA and hopefully they will reply back with something. Thanks for the help so far.
Anything from the F11 to the F14 will do wonders. I have seen as much as 470+ with the FM13 and TEA 1.5 heads. The average seems to be in the 420-440 area. Also, give Alan a call at FMS. He will be able to point you in the right direction AND they are running a cam special now too.
