Will TSP 231/237 clear with milled heads?
Old 11-29-2004, 07:37 PM
Sn8ke_Eater's Avatar
Default Will TSP 231/237 clear with milled heads?
I will like to know if the TSP 231/237 will clear my milled 5.3Lheads they are milled 0.05 its very little but you never know.Right now i am running a 226/230 590-114 its all right but want full flow of the heads.
Old 11-29-2004, 07:53 PM
Restricted User
CAT3's Avatar
If you mean .005, 5 thousandths yes. But .05, or 5 hundreds is not very little and will make ju-ju. Mine are cut, maybe a litle too much but I used Cometic gaskets to make sure I had clearance. I will try to post all the info in a couple hours.
*disclaimer* you should always check your clearance first, onus is on the owner not on me for stating that it worked for me!
Old 11-29-2004, 10:25 PM
yes my heads are milled 5 thousanths so it would clear right.
Old 11-29-2004, 10:43 PM
Restricted User
CAT3's Avatar
I would say yes, also depends on your gaskets thickness.
Stock compressed is .054-.056", so if you go with stock gaskets, you should be good. I My heads, PP2 were milled a total of .015" or about that. The Cometic gasket is .065" so it makes up for some of the milling and have no issues with P2V on stock uncut pistons. There are other gaskets available, and thicknesses should be easy enough to get from "search" in this section. Good luck.
Charlie
