Grease on light bulb?
Old 12-02-2004, 10:32 PM
AxlFerry's Avatar
Default Grease on light bulb?
I just took out my driver side DRL bulb and the bulb and socket are coated in some crap that looks like mud. A friend of mine said that was grease and was supposed to be there, is that true??
Old 12-02-2004, 10:40 PM
Vertigo's Avatar
YES!! it is supposed to be there! dont remove it... Later!
Old 12-02-2004, 10:45 PM
AxlFerry's Avatar
Thanks a lot! The bulb's burned out, I gotta replace it. I've just never seen grease like that b4!
BTW, whats the best place online to upload some pics? I just got the 1st pics of my '00 T/A developed, and I want to show it off 2 everyone.
Old 12-03-2004, 12:03 AM
2kta--89formula's Avatar
The grease is there to keep the water out......<so I was told> I had the passenger front turn signal light socket burn out on me, the guys at the dealership told me it was pretty common...any lithium grease will work. I had replaced the bulb about a week prior to the socket <didn't know about the grease at the time> only to find out that the socket fried out when water got inside and arced from one terminal to the other. When I replaced the plastic assembly it was 80% melted <I was lucky it didn't start a fire>! Hope this helps!
Old 12-03-2004, 09:13 AM
Vertigo's Avatar
http://www.cardomain.com
Im pretty sure its free also.
community.webshots.com is another i think....
Old 12-03-2004, 09:16 AM
Weezzer's Avatar
Its supposed to be silicone based (dilectric) grease.
Old 12-03-2004, 09:54 AM
tim99ws6's Avatar
Dielectric grease is AWESOME. Always keep a can of that and some electrical parts cleaner. When a bulb goes out, pull the bulb, clean the socket with the cleaner. Then let it dry, and put a tiny bead of that grease in the socket. Plug in the bulb, and it's good to go!
Tim
Old 12-04-2004, 12:27 AM
Guess I was mis-informed <damned dealers!> Sorry for the inaccurate info!! Guess I should go get some dilectric grease!
Quick Reply: Grease on light bulb?
