torquer vs 10 bolt?
torquer vs 10 bolt?
if i get the torquer (tsp 233/233) for my daily driver, do you think the 10 bolt will hold up? i'm not planning on getting sticky tires, but i would like ~400 hp. also, with .59x life how often would i need to change springs?
If you don't go to the track and don't launch on sticky tires, the 10 bolt will probably hold up... With a hard launch on Nittos with bolt-ons only, I sheared over 8 teeth (lost count after that) from the ring gear in the 10 bolt, so use at your own risk.
