corsa tips
Old 12-06-2004, 12:53 AM
SSmoked99's Avatar
Default corsa tips
if you were to buy corsa tips seperate from the whole system is the tips different from if you were to buy the whole corsa system??? Cuz that's what it looks like in the pics i've seen
Old 12-06-2004, 01:29 AM
jrp
SN95 Director
jrp's Avatar
you do know they offer more then one tip design right?
Old 12-06-2004, 04:02 AM
lsx24's Avatar
That is correct. Most likely they won't be able to find the right tips. So when you call them reference part #14035 for the f-body design (dual 3.5 pro series).
If they aren't able to find the correct part number (which is very likely with the blokes who sit around playing solitaire all day...), it's the exact same piece as the Trailblazer tip. That will run you right around $300 for a set.
Old 12-06-2004, 12:47 PM
SSmoked99's Avatar
what's the difference between the pro series tips and the tiger shark tips because they look exactly the same.
