Reading HPTuner Files ?
I know you can't read LS1 Edit files with HPTuners,but what about the other way around.I saw on here somewhere,to change the name from a bin file to a ls1 file and edit would read the tuner files.
If this is correct,how would you do that.I'm not real computer savy at times,so the more detailed the better.
Thanks,
Tony
Thanks,
Tony
in edit, go to file, open, change file type to all files, and select the .bin file
When you resave I'd assume it then encrypts the new file so it's only viewable in edit
Thanks! Worked fine.
Another question-My edit will not read '98 files(edit or tuners).Will I need to find someone who has a '98 license for edit and up grade it to the 1.5 ver.
