gettin a bigger fuel pump, think its the 255. anyway, for checking it out to have predator change the things for me, what do i need to look at the fuel trims? thanks
As long as the fuel pressure regulator is doing its job there should be no difference. You'd need a lot more mods before you'd start going lean on the top end with a stock pump
