Doing Cam Swap questions????
Okay i recentley bought a cam,i also have some comp 918's,ls6 oil pump,Chromemoly pushrods{7.400"}new timing chain and thunder racing gasket kit.Do i need anything else?
Thanx BTLFEDSS
Thanx BTLFEDSS
Make sure you got oil, coolant, loctite, rtv gasket maker, and lots of paper towels! Also make sure you got the right tools including a puller and valvespring tool. That should about cover I think.
Depending on the cam, you'll need tuning software unless you plan to have someone else do it. This link can answer all your questions for tools, parts, etc. Good luck.
http://ls1howto.com/index.php?articl...d3cd8e57dfae1a
