coolant hoses sucking together
on my 2001 ls1 engine the coolant hoses are sucking together and the heater hoses but not all the way together. The coolant system is full but losing a little not much. What is going on with this i did a conversion put new ported heads and a cam in it now all these problems. thanks for any help
If you replaced any of the hoses with cheapy aftermarket versions you may have gotten a version that isn't stiff enough. Or you may need to find one that has a spring inside to prevent them from sucking closed.
Location: Used to live in South Texas, Now in North Carolina
I bet 100 bucks you have air in the system. let the vehicle run and keep squeezing the top hose. Start it when its cold with the cap off so you can refill the level as it drops. Do this untill the vehicle reaches full operating temp.
