K&N FIPK won't fix SLP maf
Old 12-09-2004, 11:41 AM
Silver02's Avatar
Default K&N FIPK won't fit SLP maf
Just got a K&N FIPK and the tube supplied in the kit isn't wide enough to fit over my SLP maf. Anyone have this problem before?
Old 12-09-2004, 01:06 PM
WILWAXU's Avatar
It's designed for a stock MAF.
Old 12-09-2004, 02:06 PM
cyphur's Avatar
that MAF you have is 85mm. not quite gonna fit into the bellows that comes with a FIPK. but the FIPK fits over my stock MAF just fine fwiw
Old 12-09-2004, 11:10 PM
Silver02's Avatar
Finally got it stretched on but it took a lot of stretching
Called K&N today. They don't make anything larger. Hope the one on there does'nt tear.
Old 12-09-2004, 11:35 PM
ss rally red's Avatar
If it comes loose take a box cutter and trim some of the rubber out on the inside of the lip.
Old 12-09-2004, 11:47 PM
Silver02's Avatar
Thanks for the tip.
Old 12-10-2004, 12:38 PM
MASS seller approved
Time2Kill's Avatar
After it has been on there for a couple of days, it will be much easier to take off/on after that. Mine I can just basically slip on and off now. I can even get it to fit a 90mm now
