need help with tick
Old 12-13-2004, 05:17 PM
98_blk_Hawk's Avatar
Default need help with tick
I need some advice on my tick I have done the search thing and no help.
I have a very pronounced tick from 2000 rpm's to 2500 rpm's coming form the drivers side. after 2500 i cant hear it over the exhaust and other motor noise. Like I said ive done the search thing and come up with exhaust leak,o-ring,lifter,push-rod,rocker,broke valve spring,and ls1's noisy valvetrain. I need some help sorting tru it all I don't have headers but have black soot over 2 exhaust ports on the driverside manifold. So i know i have a small leak there i just dont think it could be as loud as the tick gets or be so rpm specific I would think if it was the leak it would get louder all the way thu the rpm band. I got new manifold gaskets already but havent had time to change it yet and dont want to waste the time if i need to be digging into the motor. also the motor is running as good as ever.
Old 12-13-2004, 05:45 PM
99Silkbird's Avatar
Check your headers...Mine had a very small hole in it and it was making a ticking sound every time i hit the acclerator.
Old 12-13-2004, 05:58 PM
Turo's Avatar
well, since you have an exhaust leak you will not be able to guess whether its anything else until you rule the exhaust leak out. im guessign here, but i have a feeling its an exhaust leak. i had one after doing headers on my car and it as a lot louder than what i expected an exhaust leak to sound like. good luck!
-turo
Old 12-14-2004, 04:09 PM
ttt..
