Dyno Tuning advise! Important, please read!
Guys, I just had a set of headers installed and I can tell my car is a bit out of tune now (A/F) [sluggish low end, loose feeling unless I get on it.. ]
I'm also getting a TC done at the same place next week and have scheduled for a basic tune [ adjust shift points, lock up at 35 mph etc.. ]
My question is, should I get a full dyno tune now or wait till I do a cam ?
I'm not going for a cam till late Feb/early March '05
I wouldn't be able to dish out another $450 for a full tune after a cam again if I get one done now..
So, do you think its better to get one done now or wait ? I'm not being able to decide. Please advise
Moderator
You will be fine. Just wait and get all done at the same time.
Of the cars I have worked on none of them were in bad need of tuning because of adding headers and a TC unless the EGR and AIR systems were removed for the headers.
LS1TECH Sponsor
when i did my headers/tc i just had issues at the track on the 2-3 shift it would smack the rev limiter...and of course the annoying SES light for the ory but other then that it wasnt horrible and i ran decent times even with the 2.73 gears...if anything i would just get a partial tune to clear out the codes for the headers ie egr, air, & o2's and maybe mess with the shift points a little considering you'll have some more slippage with a converter it could start tapping the limiter.
Moderator
If you aren't FI or spraying, it is not as critical. Do you have monitoring software, where you can at least keep an eye on things?
Instead of a "tuning" dyno, consider one of the "3-pull" versions that just let you see what you are doing ($50 to $100 bucks). That way, at least you will KNOW where you are at.
I'd wait until you get the cam for a dyno tune. Or you can buy tuning software and between now and February learn how to use it. Then if you make changes in the future, you won't have to pay for another tune.
