Ahhh idle airflow table needed!!
Old 12-16-2004, 08:19 PM
Terry Burger's Avatar
Default Ahhh idle airflow table needed!!
I've been toying with this table for a few days now. No matter what I do the car either goes in to cruise control mode, or the surge of death when coming to a stop. I've read all the read ups etc, and I still can't figure this stupid table out. I've got a pretty large cam (232 - 113ls) on a stock shortblock, with ported heads, headers, etc. If someone has one they could post I'd appreciate it. The right most value for PN and G (I think its 140 degrees?) would be fine.
Thanks!
Terry
Old 12-16-2004, 08:44 PM
wait4me's Avatar
hmm for that cam id do this,
20 18.5 17 15.5 15.2 10 10 10 10 10 10 10 10 10 10 10
17.6 16.21 14.78 13.5 12.76 12.1 12.1 12.1 12.1 12.1 12.1 12.1 12.1 12.1 12.1 12.1
on the base idle flow, but you need the park position airflow table also
wait4me's Avatar
here is one id use for your cam,
40.72 34.55 28.38 25.92 23.45 17.28 12.34 11.1 11.1 11.1
Old 12-16-2004, 08:45 PM
wait4me's Avatar
if it still cruises, move the 11.1 to about 10.6 or so..
Old 12-17-2004, 05:55 AM
gameover's Avatar
also remember your base airflow depends on your idle RPM table, if you set your idle RPM higher then you need to shift your airflow higher.
