3.23's to 3.73's Who made this swap? How do you like the results?
Old 12-16-2004, 08:20 PM
texada's Avatar
Default 3.23's to 3.73's Who made this swap? How do you like the results?
I already have 3.23's and a converter, but I want to tighten up the looseness. I am considering buying some 3.73 gears. Anyone of you guys had similar set-ups like mine and changed to 3.73's. If so how do you like them? Did they improve you quarter times?
Old 12-16-2004, 08:42 PM
99ssleeper's Avatar
I did 3.73s and gained 2 tenths and 2 mph in the 1/4 when my car was stock...on street tires.
The 3500 stall and 3.73s are a nice combo.
Old 12-16-2004, 08:53 PM
Black8Banger's Avatar
I went from 3.23s to 3.73s and a 3200 stall....big difference!!
Old 12-16-2004, 09:20 PM
texada's Avatar
How does the overdrive pull with the 3.73's on top end?
Old 12-17-2004, 09:32 AM
99ssleeper's Avatar
My car goes into 4th at about 120-125 mph on a 6200 rpm shift point...I can't catch 2nd gear from 70 mph anymore...now it's down to 55, it's a big kick in the butt though.
They make driving the car much more fun, but honestly, a good converter doesnt need gears. There are 2.73 geared cars that are just as fast as lower geared cars (numerically higher)....it's really all in the converter.
Old 12-17-2004, 10:27 AM
BoonesZ's Avatar
this migh tnot help much but i went from 4.10's to 3.73s and didnt notice much of a difference except i dont have to shift constantly and i have my topend back now.
Old 12-18-2004, 10:12 AM
01Z0H6's Avatar
I too have the same question. Glad you posted it.
I have the 323's with a Yank SY3500.
My car is a daily driver however.
Will it kill my gas mileage?
Even if i drive sensibly?
Old 12-18-2004, 11:24 AM
PREDATOR-Z's Avatar
3.73:1 here with vig3200
Very nice combo not too loose and kick *** acceleration.
Old 12-18-2004, 03:12 PM
LS1SS4ever's Avatar
May be 3.55 will be more reasonable
Old 12-18-2004, 04:29 PM
AFTICA's Avatar
I made the change when the car was almost stock and before my converter. Gave me only a tenth and 1 mph at the track, but felt much quicker on the street. They're probably helping me more now with the cam. For a bolt-on car I wouldn't bother. They really do tighten up converters though. With my 3.73's and the 2800 Vig, there are people who drive my car that swear it's a stock converter.
Old 12-18-2004, 06:59 PM
Tom's_03SVT's Avatar
3200-3.73 here, my city mileage is 19 and freeway is 23 i drive a little faster than most on the freeway 75-80. the engine turns 2300 RPMs at that speed.
Tom
Old 12-18-2004, 07:08 PM
WJ SOM SS's Avatar
Tom
Tom: Can you, or anyone else, tell me how much your RPM's increased over the 3.23's after installing the 3.73's when crossing the finish line of the 1/4 mile? Ever glance at the tach when crossing finish line? Thanks. WJ Oh, that woud be w/a 26" tall tire, also.
Old 12-19-2004, 09:26 AM
ULTIMATEORANGESS's Avatar
my car in OD pulls alot harder with 3.73s than with 3.23s.
in D in really gets going.
Old 12-20-2004, 08:48 AM
BAIN's Avatar
I have 3.73's in mine and in 3rd gear at the end of the 1/4 the tach says a little over 6100-6300rpm. I have my shift point set to 6100, rev. limiter at 6400 and in 3rd it will hold it through the 1/4, but if I put it in 4th it will shift before the end. I think I'm running out of gear with the 3.73's. If I were you I would stick with the 3.23's until you put a cam in it and rev higher.
Old 12-20-2004, 09:34 AM
TWISTEDTA's Avatar
I have all basic bolt on's in my Automatic WS6 do you guys think i could just keep the stockrear end and dump 3.73 gears in it-or should i just get a 12 bolt?
Old 12-20-2004, 09:42 AM
BAIN's Avatar
With 3.23 gears already keep them and get a stall
Old 12-20-2004, 09:49 AM
TWISTEDTA's Avatar
You think that will do it? I keep hearing that the rear ends on those cars junk and if i add any real power to the car it will brake. If i get a stall for an everyday driver how high should i go? And should i get a tranny cooler while im at it? Thanks for your help!
Old 12-20-2004, 10:50 AM
RahuL's Avatar
consider this... George at TTP ran a 10.5 in his '02 A4 Formula on stock suspension and rear!! I'm sure the stock rear isn't THAT bad
Old 12-20-2004, 12:42 PM
TWISTEDTA's Avatar
So what do you think should i just go with a stall n get a tranny cooler? Should i leave the rear end alone or should i dump in the 3.73 in that stock rear end? Im lost i dont know what to do at this point.
Old 12-20-2004, 12:53 PM
WJ SOM SS's Avatar
Wow, that's hard to believe. w/a 26" tire and 3.23's w/Vig 3200, I'm crossing finish line in 3rd at 45-4600 rpm. I figured 3.73's would put me at about 4800-5000 rpm's tops. Could your trans be slipping, or converter slipping that much? Anyone else contribute to this thread? Thanks. WJ
Quick Reply: 3.23's to 3.73's Who made this swap? How do you like the results?
