Info on correct size of tire...
Old 12-31-2004, 05:44 PM
bbz
bbz's Avatar
Exclamation Info on correct size of tire...
I have a set of the 15x9.75" & 15x4" Bogarts for Ls1 camaros from SJM. With a stock rear end what max. (m/t et's and/or m/t drag radials) size tire would fit without rubbing?
Old 01-01-2005, 10:39 PM
bbz
bbz's Avatar
anybody use this combo?
Old 01-03-2005, 01:20 PM
Retired Street Racer
Matt D's Avatar
27x10.5x15 et street and 275/50/15 et drag radial will fit for sure, but if you go with a 28x10.5x15 or a 275/60/15 et drag radial, it will be cutting it close, and you might have to trim a little. everyone says different things but i know the 27in and 50 tall tires will fit no problem. hope this helps
