LS1Edit MAF Table & VRam
Has anyone tried to update their LS1Edit MAF table to accurately match the gm/sec flow of a Vararam across the full MAF frequency range?
Thanks.
Thanks.
Thanks.
Thanks.
Originally Posted by Another_User
I doubt that the Vararam TB-obstruction will make any difference. It would have little, if any, affect on how air flows through the MAF. You need to update it for lids, MAF porting, aftermarket MAF, etc.
I wish I had taken more measurements with the stock setup.
I'm debating if the extra flow (at higher speeds) and cooler air would warrant any change? I could argue that left alone, it will generate higher MAF frequencies and therefore generate higher gm/sec values based on its presence.
