LT's & ORY and Eibach Sportline Lowering? Issue?
Hey I was wondering if i was to lower my 98 SS with the eibach lowering kit would it be a ground issue later when i buy pacesetters and the ORY? Thanks guys!
i wouldnt worry as much about that as opposed to the underside of the car!...anything that sticks up on the ground like speed bumps or small curb sized bumps and such...will catch that pipe...2" is too much if you ask me
Originally Posted by 5POINT7
Nahh, you'll be fine. Pacesetter's have good clearance. Just stay away from SLP longtubes.
but hey pacesetters do tuck nicer then many...so you might do fine
Trial and Error
I have pacesetters, tsp ory, and sportlines and have had no problem driving daily. I am sure that you are careful now of speedbumps etc., it is not that much different. I would recomend getting a pro kit instead of sportlines because the ride is sooo much better and the rate is stiffer. If I would do it again I would have got the pro kit because ther is not that much difference in height.
