alternator only
Old 01-04-2005, 10:15 AM
SERPENT99's Avatar
Default alternator only
Anyone know a good solution to drive only the alternator off the crank? I don't know if I should use a tensioner or make an adjustable bracket. it's in a 2002 TA where the alt is mounted low on the drivers side
Old 01-04-2005, 10:47 AM
NLang's Avatar
Just slot one of the holes on the mounting bracket so you have atleast a little adjustment for belt-stretch.
Old 01-04-2005, 06:17 PM
WILWAXU's Avatar
Here's one way to do it:
https://ls1tech.com/forums/generation-iii-external-engine/255224-ultimate-short-belt-setup.html
