opinions on setup
opinions on setup
whats up guys just wanted your opinions on the setup i am going to start soon. Street Fighter Torque Converter, 3500 Stall Speed, 2.5:1 STR, tranny cooler, drag radials, and ls6 cam. not sure on cam yet but its what im leaning toward. i don't want something to lopey and want to remain streetable. suggestions?
wondering weather the stall is to big for the cam? cam to small for stall. if i decide not to buy the cam is there anything i shud by with the stall,tranny cooler and radials to help all around performance?
As for the stall, I think it sounds good. Depending on your gears, it may make it hard to get traction even with drag radials. I think you should also invest in a Transgo Shift Kit; it'll firm up your shifts, prolong the life of your tranny, and take some of the loose feeling out the stall while driving around.
thanks alot i am def going with stall+radials. done my research on that just curious about a cam that would work with that stall. shift kit and tranny cooler along with the stall gotcha. btw i have 2.73's? harder to hook up on drag radials?
