stock lifter preload.
Regardless of what rocker arms, etc. that you are using, What is the minimum and maximum preload on stock (or stock replacement) lifters? Is the preload the same regardless of what size, type, etc. of the cam you use? I am tired of using the search function (too much old info). I want the numbers in a numeric value, not 1 turn, 1/2 turn, etc.
