ATI hub install
ATI hub install
Purchased a length of 16mm X 2.0 hardened threaded rod with nut, used bearing form K-D P/S pulley puller, heat ATI hub in boiling water and stack all this stuff on top of the ARP washer that comes with their bolt and tighten down hub. Remove hardware, reinstall bolt with washer and locktite,torque to 190
