LS1 wouldn't run after a WOT run
A few nights ago I did a WOT run from a stop and I hit a wet spot on the street causing my RPMs to shoot up and I bounced off the rev limiter about 2-4 times. I then shifted into second where the car then proceeded to bog heavily (no power). I pulled over and then the car wouldn't idle and I had a service engine soon light on. It idled barely, but at around 200-400rpms and then just die. I let it sit for 5 minutes and tried again, but the same thing happened. I called my friend who is a mechanic and he stopped by about 15-20minutes later. He went to start it up and it started fine no problems and no service engine soon light. What happened? He thought the timing chain might have stretched or skipped a tooth, but then it started right up. The car seems to run fine now, anyone know what happened?
edit: The car is completely stock, 117,000 miles 1998 WS6
Is it possible that the knock sensor might be bad? I had a few similar problems once in a while where I would go WOT and shift into second with the same bog...but then I just skipped to 4th and drove away. It happens once in a blue moon though, but should it be something I should worry about?
Originally Posted by 98hawk
Same thing happened to me when I went into second on a 3 to 4 shift. Only I bent pushrods and valves. Ha, Thank your rev limiter and be glad that it wasn't a missed shift.
Hmmm well I don't miss shift so i should be ok :p
