Is this the PERFECT offset for my WS6 for ZO6 wheels
SIZE AND SPECIFICATIONS: We have two different size wheels on this auction. The fronts are 17"x9.5" (+56mm offset) and the rears are the WIDE 18"x10.5" (+56mm offset). The lug pattern is 5x120.65mm.
http://cgi.aol.ebay.com/ebaymotors/w...MakeTrack=true
It will work, but it depends on what look you're going for. If you want them to be flush with the rear wells then that's not gonna happen with a 56MM offset. They'll still look good.
I'm currently trying to get the proper offst in the ZO6 wheels to clear my StopTech brakes up front. I want to run 18X9.5 fronts with 18X10.5 rear. From the mounting pad straight out(for spokes to clear the calipers is 37mm. Currently running WS6 wheels with a 1/2in spacer for the proper brake clearence. Already have one set of TT2s that the spokes won't clear unless I run a 3/4 spacer. Any help would be GREATLY APPRECIATED!!!!!
