Meziere pump, looking for thermo and housing
Old 01-17-2005, 02:14 PM
GrannySShifting's Avatar
Default Meziere pump, looking for thermo and housing
is it all the same as traditional SBC stuff, or is just the thermostat the same? Anyone know where i can get the neck and a thermostat?
Old 01-17-2005, 04:56 PM
strokedls1's Avatar
I just bought a 160 sbc thermostat and drilled it out as per the instructions. Then I bought a 45 degree chrome water neck from kragen for 10 dollars. The hose can be reused with a kink in it like I'm doing, or use one of those accordian style cooling tubes like my friend did. I used some silicone to seal the water neck as it was leaking a little. Been working great for over a year now.
Old 01-17-2005, 08:14 PM
anything bolt in looks good?
Old 01-17-2005, 10:19 PM
strokedls1's Avatar
Forgot to say that I also had to grind the mounting bolt holes out a little with a drill on the water neck, and buy the bolts. Took ten minutes to do out of the car.
