Who Has Painted The Exterior Oftheir Car?!?
Well I got my Ground Effects today for my Formula, to match with my t/a wing. But im thinking to do the work myself, but I REALLY WANT THE COLOR TO MATCH. I have a paint gun , and have painted stuff before on it and have came out awesome. But im just not sure on how hard it might be. The origional paint is white, and i need it to be nbm. Is there any way i can order a small cannister of GM's NBM, and do the work myself??.... Or should i just fork over around 100$ to get the damm things painted....
HERE IS THE CAR NOW
HERE IS THE CAR NOW
Car looks pimp without the door handles......i'd say fork over the money to a bady shop man.....even though it's possible to do it yourself....the car looks too badass to mess up your new ground effects!! Just my 2 cents!
If you have a paint gun and know what your doing, why not do it yourself? The worst thing thats gonna happen is your gonna waste $30 for the paint you had mixed up.
But to answer your question alot of autoparts stores can get you the paint you need, or direct you somewhere that can. And some good places have a crazy camera that they take a pic of your paint with, and match it exactly.
go to just about any place that sells automotive paint, they can give you the exact paint from the paint code on the car, or shoot it w/ the color gun and know exactly what color it is unless its a transparent color (candy.. ect..), but most likeley there's a color book and just look up 1998, GM, NBM..... I would charge at least $200 to do a gfx kit includeing watersanding and buffing... it might be alot easier to just have somebody else paint it for $100 if that includes the prep, paint, finishing, and if they do a quality job.... if you d.i.y. and have a paint gun and compressor just make sure your mixing ratio's are right, let it flash to specs, make sure you have good fill on the color, and once the clear is on its easy to get any surface imperfections out... also have a good compressor filter and WEAR SAFTEY EQUPMENT!!! you should know that much and everything else if you've painted before...
