How to tell if head has been milled?
Old 01-27-2005, 09:53 PM
mr2guru's Avatar
Default How to tell if head has been milled?
Is there a measurement I can take of a LS1 head to check if it has been milled? i.e. Deck surface to valve cover gasket surface? If so anyone have the measurement offhand?
241 casting
Thanks
Old 01-28-2005, 08:12 AM
Gunnar@Patriot's Avatar
241 casting
Thanks
If you measure at the end of the head, from valvecover rail to the deck of the head, the unmilled measurement should be 4.750"
Old 01-28-2005, 01:12 PM
mr2guru's Avatar
Thanks Gunnar.....exactly what I was looking for
Old 01-28-2005, 02:35 PM
Not a problem. Glad we could help.
Old 01-29-2005, 02:07 AM
mr2guru's Avatar
It was difficult to come up with exact repeatable #s from my dial caliper but I kept getting 4.748 So for all intensive purposes they are unmilled? How much is usually taken off when just resurfaced? .001 or so?
Old 02-08-2005, 01:55 PM
smoothzee's Avatar
Default height of LQ9 head
Can you tell me what the height of an LQ9 head is? I'm trying to determine how much I can mill to achieve a compression ration of 10.5:1 or so on an LS1 block with a 224/224-114 cam without piston to valve problems. Thanks for your help.
Quick Reply: How to tell if head has been milled?
