So what exactly causes cam surge?
Old 01-28-2005, 04:19 PM
DVST8OR's Avatar
Default So what exactly causes cam surge?
What is it exactly that causes cam surge, i.e. making the car buck and kick? Is it bad / should be avoided?
Thanks,
Brian
Old 01-28-2005, 05:08 PM
TNormZ28's Avatar
airflow and timing.
Old 01-28-2005, 09:11 PM
z98
z98's Avatar
Usually associated with big cams, caused by the disturbance of air induced by the large overlap of said large cams.
Old 01-28-2005, 09:27 PM
pkincy's Avatar
[QUOTE=DVST8OR]What is it exactly that causes cam surge, i.e. making the car buck and kick? Is it bad / should be avoided?
Typically air fuel ratio. typically tuned by getting enough timing at the surging rpm to rebuild the cylinder pressure that the overlap is losing and also optimizing the "running airflow" table also called "idle air".
Perry
Old 01-29-2005, 04:42 PM
DVST8OR's Avatar
Is it bad for the engine? Or is the fact that its annoying the only drawback?
