Question about Madman's motorplates
ok i did a search,and didnt quite find what i wanted.
im looking into motorplates,i know he has a front plate,but curious as to what everyone is doing about a midplate. do you have 1? if not,what trans mount are you running? do you have any other brace?
Brian,so if you dont run a midplate,does the transmount support the back1/2 of the combo?
maybe im just thick skulled,but i think there should be something in the middle.
Thanks
Thanks
1 Post
Hey Brian...
I have a BMR Tubular K-member.. and there is no way to remove the motor mounts braces like on a stock K-member. I was thinking about keeping my setup the way it is using the motor mounts on the side of the block + the tranny mount etc and adding the front motor plate. Having these 3 mounting points, would you still recommend the mid plate?
I have a feeling im leaving some rwtq on the table by not using a motor plate in my setup. Would be nice also to get rid of my vacuum pump bracket and mount my pump to the plate.
Lee
Lee
