Piston rings for LQ9 (6.0L)
Hi, can someone give me manufacturers and part numbers for piston rings for the LQ9 engine? I have found that these are 1.5mm compression rings and a 3mm oil control ring, and the bore diameter is 4.000". I won't be boring my cylinders, just a slight hone so I need file fit rings. What options do I have?
