Can 99+ knock sensors be used on a '98 LS1?
Originally Posted by V-10 Killer
If I changed the wiring harness too, could the newer knock sensors be used on an older block/PCM?
I'm just wondering in case I fail to be able to de-sensitize them via HP Tuners.
I have a set in my 98 and have not seen a "real" difference in reduced knock. Looking back I would do it again yes... because the 98 have had known bad sensors.
make sure you do the RTV seal TID
