i need help bad
i need help bad
i took my car up to Auto Zone a few days ago and had em check a few codes. threw up a couple codes said im running lean bank 1 and 2, o2 sensors.... probably fouled em out when i was running open headers, and a camshaft position sensor code. i have no clue whats causing the cam pos. sensor code. i really need to get this worked out, any suggestions would be helpful, or any suggestions of where to get it looked at/ fixed for a good price
whats actually goin on with the car; whenever i try to turn the key over it backfires, a couple trys later it'll start up. before my headers were put on (with just a fra and a cut-out) i kept up with a 01 z with intake.... but after my headers and true duals (no cats no mufflers) im losing by a car length or two.... could this be because of no backpressure cuz of the no cats or mufflers? or maybe the camshaft position sensor which is more than likely a serious problem?
if you have any suggestions id appreciate them
thanks
-eric
thanks
-eric
