what radials can i get for the front?
i've decided to run 15x10 prostars on the rear with 315 MT ET DRs and go with the 15x3.5s in the front. now the guy at summit told me they don't have a radial to fit that size front rim. he also said i can't mix the tires, run DRs on the back and run a skinny tire that would be used with regular slicks. what are my options, if any? i don't want to run slicks, want to stay with drag radials.
thanks
will
thanks
will
I don't think you will find a radial front as tall as the 315 mickey that wil fit a 3.5 rim.
A least I wasn't able to find oneand I looked everywhere.Now if you don't care if the height matches you can go to pep boys and get a set of the metric radials 165x15
thatare around 26 inches tall.Just got a set for mine for $90 mounted,the only downside is the abs won't work .
